Small Business- ESW-520-48P-K9
Answered Question
May 26th, 2010
I need to decide on few things regarding this switch before recommending this switch to my customer. I have the following questions that i need some expert advice.
Questions
1.) Does this switch support POE 15.4W on all 48 10/100 ports (ESW-520-48P-K9). The total power rating of this switch is only 370W and if this divided with 48 ports, each port can only drive 7W. So thus the confusion.
2.) /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} Can the ESW Series be Monitored and Managed using Ciscoworks LMS?
3.) Is MGBSX1 compatible with GLC-SX-MM
Thanks.
Correct Answer by Ganesh Hariharan about 7 years 4 days ago
Questions
2.) Can the ESW Series be Monitored and Managed using Ciscoworks LMS?
Thanks.
Please see the attached document for your queries !!
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Thu, 05/27/2010 - 02:10
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Questions
Thanks.
Hope to Help !!
Ganesh.H
yathis1899 Thu, 05/27/2010 - 02:21
Thanks you for the reply and the doc did helped to clear all my doubts.
Cheers.
