SF100D-05/Datastream problem
May 27th, 2010
Hi Community
This new desktop SF100D-05 switch have problems, when connecting to the PAP2T-EU VOIP Adaptor.
The LED linklamp is indicate that the link is okay, but there is no datastream, between the units.
If they replace the SF100D-05 with the "old"  SD208-EU, it work without problems.
Have you seen this issue before??
jdemmer Thu, 06/03/2010 - 01:47
Steen,
thanks for bringing this up, I haven't seen this behavior before.
We'll look into this and report back to you asap.
Thanks!
BR
Jens
Franck JOLY Sun, 07/11/2010 - 03:50
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
You’re not alone with this trouble!
I confirm this compatibility issue except if PAP2T (5.1.6-LS) is connected on port 5…
This strange comportment have been verified with 2 different SF100D-05 (SD205T V01)
