Application not working on CSM
May 27th, 2010
Hi ,
Could some one explain whats the difference between the using the port and using the Any while configuring VIP on CSM?
After configuring "Any" keyword under the context the application is not  working.
(NOTE: If I change it to http it works eg:virtual 192.168.1.1 tcp http/port  number)
Example:
vserver usa
virtual 192.168.1.1 tcp any  :-----If i change this "any" keyword with  tcp  port number it works
  replicate csrp sticky
  replicate csrp connection
  no persistent rebalance
  slb-policy fariha
  inservice
policy fariha
sticky-group 4
serverfarm zain
sticky 4 cookie zain insert
The IOS running on the CSM is 2.2(3)
Any help would be appriciated.
Fariha
Kristopher Martinez Thu, 05/27/2010 - 10:39
  • Cisco Employee,
The "tcp any" will allow connections to that Virtual IP on any TCP port.  If it is
working using the specific port, it should be working using any.  Keep in mind that the CSM will accept and load balance using "tcp any," b
ut your server may not be listening on that port and will reset the connection.
As a best practice, you should define the specific port on the vserver for load balancing.  Using the "any" statement has it's purposes, but for general load blancing define the tcp/udp port number for your application.  This is also more secure.
Kris
