3560 boot error
Andy White
Level 3
Level 3
I have a 3560 that boots up fine but has I do get some errors and don't know why.  I get theis error:
Loading "c3560-ipservicesk9-mz.122-53.SE2.bin"...c3560-ipservicesk9-mz.122-53.SE2.bin: no such device
Error loading "c3560-ipservicesk9-mz.122-53.SE2.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipservicesk9-mz.122-53.SE2.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Here is my flash:
3560_1#sh flash
Directory of flash:/
    2  -rwx        3841   Mar 1 1993 00:05:55 +00:00  private-config.text
    3  -rwx        3096   Mar 1 1993 00:07:54 +00:00  multiple-fs
    4  -rwx        3312   Mar 1 1993 00:05:55 +00:00  config.text
  463  -rwx    12484113   Mar 1 1993 00:40:03 +00:00  c3560-ipservicesk9-mz.122-53.SE2.bin
32514048 bytes total (20017152 bytes free)
3560_1#
Here is part of my version info:
3560_1 uptime is 1 minute
System image file is "flash:/c3560-ipservicesk9-mz.122-53.SE2.bin"
What do you think?
spremkumar
Level 9
Level 9
Can you check the boot commands in your switch ? i feel there are 2 pointers one just pointing the ios.bin file and another with the path flash:ios.bin.
Remove the first entry so that it dont give you the error message.
regds
Hi, there is no boot commands, I did try:
boot system c3560-ipservicesk9-mz.122-53.SE2.bin
But it still shows the error, plus this command doesn't show up in the config after reboot.
Remove the boot statement using the command "no boot system".
