Cisco IOS and CME Version for Cisco 3845
May 27th, 2010
We are planning to install Call Manager Express on our Cisco 3845 router. However, I do not know which version to install and which IOS. I tried to check the Cisco IOS and CME Compatibility Matrix page and saw that version 4.1 is the recommended version and it is supported starting 12.4(15)T7 IOS. I already downloaded CME 4.1 but I can't choose which IOS to install. I'm trying to download 12.4(15)T7 but Cisco warned me that it has a problem (you know when Cisco warns you whenever you are downloading a broken IOS). So I planned to choose other version but I'm having a hard time choosing which IOS will fit both IOS and CME on a 128MB flashcard.  I am now downloading 12.4(11)XW7 IP Voice but I'm not 100% sure if CME 4.1 will work on this platform. Can anyone help me choose the right IOS? Thanks.
John
Md. Mijanur Rahman Fri, 05/28/2010 - 05:46
  • Silver, 250 points or more
You can run the version 12.4(15)T7, see every IOS has some issues more or less, every IOS has some known issues, and Cisco warns about those before you download it, read the defects before downloading it for that particular IOS and try to match your requirement, if any serious issue is there then look for next version like 12.4(15)T8 and so on.... I am using 12.5(20)T10 for long days and didn't find any issue so far. Also i'm not sure the version 12.4(11)XW7 supports CME 4.1 or not, check the compatibility matrix and that's the best practice.
John Patrick Lopez Sun, 05/30/2010 - 18:37
Thanks for the reply. I checked the software feature tool of Cisco but I cannot find version 4.1 Instead, I found 4.0(1). Base from there, the IOS that I downloaded supports version 4.0(1).
How do i determine if the CME version that the IOS is running? Thanks.
John Patrick Lopez Sun, 05/30/2010 - 18:45
I think I'm using 4.2.
PHKPTGTW001#sh version | i IOS
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2)
PHKPTGTW001#sh telephony-service | i Express|Version
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
PHKPTGTW001#
So I guess I should upload the correct phone firmwares on the router. I uploaded the following files from the 4.1 zip file. Well is it backward compatible? Thanks.
PHKPTGTW001#sh flash:
System CompactFlash directory:
File  Length   Name/status
  1   42912332  c3845-ipvoicek9-mz.124-11.XW7.bin
  2   129828   P00308000400.bin
  3   461      P00308000400.loads
  4   701768   P00308000400.sb2
  5   130232   P00308000400.sbn
  6   2759     Readme7960-40.txt
  7   4802     admin_user.html
  8   672015   admin_user.js
10   716      CME_GUI_README.TXT
12   16344    dom.js
14   6146     ephone_admin.html
16   3724     normal_user.html
17   81443    normal_user.js
21   2431     telephony_service.html
23   9968     xml-test.html
24   3412     xml.template
[44691252 bytes used, 83759304 available, 128450556 total]
125440K bytes of ATA System CompactFlash (Read/Write)
PHKPTGTW001#
John
