05-27-2010 10:32 AM - edited 03-04-2019 08:36 AM
Hi all,
I have a simple 2ISP 1Local Router setup with BGP on each ISP. I was able to configure load-share without any problems, only thing that i noticed is the CPU usage I'm getting (please see below)
CPU utilization for five seconds: 86%/1%; one minute: 82%; five minutes: 81%
one of my ISP's is pushing a full-route and NOC explains that I need to have a better hardware? (I already have this 7206VXR with an NPE-G2).
I'm still scouring the forums to see if there are people that have the same issue as me.On my config i have inbound traffic with sanity filters (bogon) I don't have any outbound filters though.
Any help would be awesomely appreciated.
thanks,
-b
05-27-2010 10:54 AM
Hello Darwin,
post
sh proc cpu sorted 1min
sh proc cpu history
cpu can be high during the loading phase for several minutes but later it should lower
Be also aware that the device is still software based and even with CEF enabled all packets are moved by main cpu so forwarding 500 Mbps per direction can be enough to have very high cpu
first show will tell what processes use more resources, from your show we see that cpu usage by interrupts is low and this leads to processes.
Hope to help
Giuseppe
05-27-2010 11:02 AM
Hi here's the result.
CPU utilization for five seconds: 83%/0%; one minute: 83%; five minutes: 82%
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
105 2584414912 58592581 5761 21.90% 22.61% 22.92% 0 IPAM Manager
20 2814555680 32015137 6124 21.58% 13.79% 13.38% 0 EnvMon
103 2710707040 6140637 7435 3.83% 5.48% 5.96% 0 ADJ resolve proc
141 2120563040 6692590 6734 3.59% 4.71% 4.26% 0 TCP Timer
123 2222039744 8110687 6098 3.59% 3.67% 3.69% 0 SSS Feature Time
169 3879587520 3389765 7479 2.31% 3.24% 2.84% 0 BGP Router
109 318269632 5963487 5815 1.51% 1.80% 1.78% 0 IP Input
168 2886543520 4015761 6066 1.91% 1.80% 1.80% 0 Inspect process
171 2880959520 4015762 6065 1.75% 1.80% 1.80% 0 CCE DP URLF cach
218 1087365408 1133918 8534 1.35% 1.54% 1.31% 0 BGP I/O
138 2251942816 3067937 6333 1.11% 1.26% 1.29% 0 CEF: IPv4 proces
290 1521644704 610631 9525 0.71% 1.12% 0.94% 0 BGP Task
24 285122112 2154067 6114 0.95% 0.98% 0.95% 0 ARP Background
49 29110112 2076479 6219 0.95% 0.95% 0.95% 0 Per-Second Jobs
38 4179421408 2076476 6149 0.95% 0.94% 0.95% 0 GraphIt
76 4131801408 2076477 6126 0.95% 0.94% 0.95% 0 ISA Common Helpe
84 3903477408 2076476 6016 0.87% 0.94% 0.95% 0 ATM PA Helper
159 49062112 2053018 6299 0.95% 0.92% 0.93% 0 RUDPV1 Main Proc
161 3886637408 2052986 6077 0.95% 0.92% 0.93% 0 bsm_xmt_proc
156 4259241408 2053039 6258 0.95% 0.92% 0.93% 0 ATMSIG Timer
48 3896529408 2052981 6082 0.95% 0.91% 0.94% 0 TTY Background
88 3695385408 2017541 6089 0.95% 0.91% 0.90% 0 Ethernet Timer C
198 3694485408 2017538 6088 0.95% 0.91% 0.90% 0 BGP Scheduler
15 3697317408 2017544 6090 0.87% 0.91% 0.90% 0 IPC Periodic Tim
16 3696469408 2017544 6089 0.87% 0.91% 0.90% 0 IPC Deferred Por
189 4113497408 2024599 6274 0.95% 0.87% 0.88% 0 PfR BR Learn
253 3856693408 2024581 6147 0.79% 0.86% 0.87% 0 trunk conditioni
5 3866820704 442884 18428 0.00% 0.82% 0.82% 0 Check heaps
134 3704860000 376859 9830 0.15% 0.76% 0.65% 0 IP RIB Update
291 1777304704 58140 104442 0.00% 0.65% 0.68% 0 BGP Scanner
152 2046716704 1034741 6128 0.39% 0.46% 0.45% 0 ILMI Timer Proce
85 2944000 290 10151 0.00% 0.44% 0.28% 0 Exec
65 3840044000 613465 6259 0.15% 0.28% 0.28% 0 HC Counter Timer
2 2507052000 415296 6036 0.23% 0.19% 0.18% 0 Load Meter
61 2580436000 415297 6213 0.23% 0.19% 0.18% 0 Compute load avg
19 2491284000 414655 6008 0.15% 0.18% 0.17% 0 IPC Loadometer
14 2524588000 414346 6092 0.15% 0.18% 0.17% 0 IPC Service NonC
45 2130932000 221923 9602 0.31% 0.14% 0.12% 0 Net Background
64 346024000 51246 6752 0.00% 0.14% 0.04% 0 Transport Port A
98 1757672000 280465 6266 0.15% 0.12% 0.11% 0 CDP Protocol
248 1264924000 207408 6098 0.15% 0.09% 0.10% 0 RMON Recycle Pro
186 1288200000 206973 6224 0.15% 0.09% 0.10% 0 XSM Historian
185 1286420000 206973 6215 0.15% 0.09% 0.10% 0 XSM_ENQUEUER
80 1258148000 208834 6024 0.15% 0.09% 0.10% 0 ATM Periodic
195 843740000 138383 6097 0.00% 0.05% 0.05% 0 ACE policy loade
170 817096000 133817 6106 0.00% 0.05% 0.05% 0 FW DP Inspect pr
230 632936000 103798 6097 0.00% 0.04% 0.04% 0 IPSEC key engine
197 522008000 83061 6284 0.00% 0.02% 0.00% 0 CRM_CALL_UPDATE_
128 263632000 42123 6258 0.23% 0.02% 0.00% 0 CEF background p
23 628608000 70115 8965 0.00% 0.02% 0.03% 0 ARP Input
142 1548852000 259460 5969 0.00% 0.02% 0.03% 0 TCP Protocols
288 211280000 34602 6106 0.00% 0.01% 0.00% 0 DFS flush period
252 396428000 64880 6110 0.00% 0.01% 0.00% 0 Crypto cTCP proc
1 89364000 11318 7895 0.00% 0.01% 0.00% 0 Chunk Manager
135 215296000 34603 6221 0.00% 0.01% 0.00% 0 Call Home Timer
269 340080000 54651 6222 0.00% 0.01% 0.00% 0 EEM ED Timer
131 217276000 34672 6266 0.00% 0.01% 0.00% 0 SSCOP Timer
132 218520000 34684 6300 0.00% 0.01% 0.00% 0 IP Background
62 386248000 35284 10946 0.00% 0.01% 0.00% 0 Per-minute Jobs
12 214752000 34603 6206 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
289 223220000 35636 6263 0.00% 0.00% 0.00% 0 Archive Config
54 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
63 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon
53 0 1 0 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
52 0 2 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
66 8000 2 4000 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN
67 0 1 0 0.00% 0.00% 0.00% 0 Coproc Event Pro
68 0 1 0 0.00% 0.00% 0.00% 0 POS APS Event Pr
69 0 1 0 0.00% 0.00% 0.00% 0 SONET alarm time
70 0 1 0 0.00% 0.00% 0.00% 0 CSP Timer
71 204000 4 51000 0.00% 0.00% 0.00% 0 USB Startup
72 8000 2 4000 0.00% 0.00% 0.00% 0 FPD Management P
73 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
60 0 1 0 0.00% 0.00% 0.00% 0 Net Input
75 0 1 0 0.00% 0.00% 0.00% 0 RF_INTERDEV_SCTP
51 320000 60 5333 0.00% 0.00% 0.00% 0 IF-MGR event pro
77 0 2 0 0.00% 0.00% 0.00% 0 Flash MIB Update
78 0 216 0 0.00% 0.00% 0.00% 0 Flash Card Oir
79 0 1 0 0.00% 0.00% 0.00% 0 CF_INTERDEV_SCTP
50 4000 18 222 0.00% 0.00% 0.00% 0 IF-MGR control p
59 0 1 0 0.00% 0.00% 0.00% 0 RF High Priority
82 264000 53 4981 0.00% 0.00% 0.00% 0 ATM OAM Input
58 4000 2 2000 0.00% 0.00% 0.00% 0 rf task
57 0 1 0 0.00% 0.00% 0.00% 0 IPSEC HA Mgr
46 0 2 0 0.00% 0.00% 0.00% 0 IDB Work
86 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
87 8000 2 4000 0.00% 0.00% 0.00% 0 Ethernet CFM
44 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
56 0 1 0 0.00% 0.00% 0.00% 0 IKE HA Mgr
90 4000 2 2000 0.00% 0.00% 0.00% 0 AAA Server
91 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
55 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-HA
74 0 1 0 0.00% 0.00% 0.00% 0 RF_INTERDEV_DELA
81 0 1 0 0.00% 0.00% 0.00% 0 ATM ARP INPUT
95 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
96 4000 2 2000 0.00% 0.00% 0.00% 0 EAPoUDP Process
97 4000 2 2000 0.00% 0.00% 0.00% 0 IP Host Track Pr
43 0 1 0 0.00% 0.00% 0.00% 0 VSA Cleanup Proc
99 4000 2 2000 0.00% 0.00% 0.00% 0 AAA Dictionary R
100 4000 2 2000 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
101 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
102 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
42 4000 2 2000 0.00% 0.00% 0.00% 0 VSA background
104 4000 2 2000 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
41 4000 2 2000 0.00% 0.00% 0.00% 0 XML Proxy Client
106 4000 2 2000 0.00% 0.00% 0.00% 0 IPAM Events
83 4000 2 2000 0.00% 0.00% 0.00% 0 ATM OAM TIMER
108 4000 1 4000 0.00% 0.00% 0.00% 0 IP ARP Retry Age
40 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
110 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
111 12000 3 4000 0.00% 0.00% 0.00% 0 PIM register asy
47 197972000 27210 7275 0.00% 0.00% 0.00% 0 Logger
89 0 1 0 0.00% 0.00% 0.00% 0 delayed evt hand
114 4000 2 2000 0.00% 0.00% 0.00% 0 KRB5 AAA
115 21208000 3458 6133 0.00% 0.00% 0.00% 0 MOP Protocols
116 8000 2 4000 0.00% 0.00% 0.00% 0 PPP SIP
117 4000 2 2000 0.00% 0.00% 0.00% 0 PPP Bind
118 8000 2 4000 0.00% 0.00% 0.00% 0 PPP IP Route
120 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager
121 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
122 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
39 4000 2 2000 0.00% 0.00% 0.00% 0 Dialer event
124 4000 2 2000 0.00% 0.00% 0.00% 0 Spanning Tree
92 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
126 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
127 4000 2 2000 0.00% 0.00% 0.00% 0 Ethernet LMI
37 0 1 0 0.00% 0.00% 0.00% 0 RFS server proce
129 4000 2 2000 0.00% 0.00% 0.00% 0 SSCOP Input
130 8000 2 4000 0.00% 0.00% 0.00% 0 SSCOP Output
93 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
94 42188000 6922 6094 0.00% 0.00% 0.00% 0 Authentication P
133 2152000 187 11508 0.00% 0.00% 0.00% 0 IP Connected Rou
36 4000 2 2000 0.00% 0.00% 0.00% 0 SMART
107 492000 77 6389 0.00% 0.00% 0.00% 0 IP ARP Adjacency
136 1016000 44 23090 0.00% 0.00% 0.00% 0 Collection proce
137 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Inspect Tim
35 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
139 204000 39 5230 0.00% 0.00% 0.00% 0 ADJ background
140 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
34 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
33 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
143 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
144 42288000 6922 6109 0.00% 0.00% 0.00% 0 HTTP CORE
32 4000 2 2000 0.00% 0.00% 0.00% 0 Serial Backgroun
31 812000 7 116000 0.00% 0.00% 0.00% 0 PrstVbl
147 100000 21 4761 0.00% 0.00% 0.00% 0 SCTP Main Proces
148 0 1 0 0.00% 0.00% 0.00% 0 SNMP Timers
149 4000 2 2000 0.00% 0.00% 0.00% 0 ILMI Input
150 4000 2 2000 0.00% 0.00% 0.00% 0 ILMI Request
151 4000 2 2000 0.00% 0.00% 0.00% 0 ILMI Response
30 103072000 13740 7501 0.00% 0.00% 0.00% 0 EEM ED Syslog
153 48000 8 6000 0.00% 0.00% 0.00% 0 ATM PVC Discover
154 4000 2 2000 0.00% 0.00% 0.00% 0 ATMSIG ILMI Time
155 4000 2 2000 0.00% 0.00% 0.00% 0 ATMSIG DRIVERAPI
29 16000 4 4000 0.00% 0.00% 0.00% 0 Entity MIB API
157 4000 2 2000 0.00% 0.00% 0.00% 0 ATMSIG Input
158 8000 2 4000 0.00% 0.00% 0.00% 0 ATMSIG Client
28 4000 2 2000 0.00% 0.00% 0.00% 0 DDR Timers
160 0 1 0 0.00% 0.00% 0.00% 0 bsm_timers
112 328000 75 4373 0.00% 0.00% 0.00% 0 TurboACL
162 8000 2 4000 0.00% 0.00% 0.00% 0 PPP Compress Inp
163 4000 2 2000 0.00% 0.00% 0.00% 0 PPP Compress Res
164 0 1 0 0.00% 0.00% 0.00% 0 COPS
165 4000 2 2000 0.00% 0.00% 0.00% 0 Dialer Forwarder
166 8000 3 2666 0.00% 0.00% 0.00% 0 Flow Exporter Ti
167 4000 2 2000 0.00% 0.00% 0.00% 0 SDEE Management
26 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
25 8000 2 4000 0.00% 0.00% 0.00% 0 ATM Idle Timer
22 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
113 4000 2 2000 0.00% 0.00% 0.00% 0 TurboACL chunk
125 4000 2 2000 0.00% 0.00% 0.00% 0 SSM connection m
173 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
174 476000 82 5804 0.00% 0.00% 0.00% 0 static
175 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
176 0 1 0 0.00% 0.00% 0.00% 0 LAPB Process
177 8000 2 4000 0.00% 0.00% 0.00% 0 PPP NBF
178 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
179 4000 2 2000 0.00% 0.00% 0.00% 0 X.25 Background
180 0 1 0 0.00% 0.00% 0.00% 0 MQC Flow Event B
181 0 2 0 0.00% 0.00% 0.00% 0 HQF Shaper Backg
182 4000 2 2000 0.00% 0.00% 0.00% 0 URL filter proc
183 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
184 0 1 0 0.00% 0.00% 0.00% 0 XSM_EVENT_ENGINE
18 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Control
17 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
187 0 1 0 0.00% 0.00% 0.00% 0 IPS Process
188 4000 2 2000 0.00% 0.00% 0.00% 0 IPS Auto Update
13 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
190 0 1 0 0.00% 0.00% 0.00% 0 Select Timers
191 4000 2 2000 0.00% 0.00% 0.00% 0 HTTP Process
192 8000 2 4000 0.00% 0.00% 0.00% 0 CIFS API Process
193 4000 2 2000 0.00% 0.00% 0.00% 0 CIFS Proxy Proce
194 4000 1 4000 0.00% 0.00% 0.00% 0 Crypto HW Proc
27 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
196 4000 2 2000 0.00% 0.00% 0.00% 0 VSP_MGR
11 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
10 4000 2 2000 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
199 4000 2 2000 0.00% 0.00% 0.00% 0 ENABLE AAA
200 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
201 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
202 0 1 0 0.00% 0.00% 0.00% 0 FW_TEST_TRP
203 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
204 4000 2 2000 0.00% 0.00% 0.00% 0 LINE AAA
205 8000 2 4000 0.00% 0.00% 0.00% 0 LOCAL AAA
206 4000 2 2000 0.00% 0.00% 0.00% 0 TPLUS
207 4000 2 2000 0.00% 0.00% 0.00% 0 AAA Cached Serve
208 8000 3 2666 0.00% 0.00% 0.00% 0 Crypto WUI
209 4000 2 2000 0.00% 0.00% 0.00% 0 Crypto Support
210 0 1 0 0.00% 0.00% 0.00% 0 EPM MAIN PROCESS
211 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP
212 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2
213 0 1 0 0.00% 0.00% 0.00% 0 EPHONE MWI Refre
214 14088000 2308 6103 0.00% 0.00% 0.00% 0 FB/KS Log HouseK
215 4000 2 2000 0.00% 0.00% 0.00% 0 EPHONE MWI BG Pr
216 0 1 0 0.00% 0.00% 0.00% 0 Skinny HW confer
217 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE
9 4000 2 2000 0.00% 0.00% 0.00% 0 ATM AutoVC Perio
219 0 1 0 0.00% 0.00% 0.00% 0 http client proc
221 0 1 0 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
222 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN
223 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA
224 4000 2 2000 0.00% 0.00% 0.00% 0 Dialog Manager
225 76000 10 7600 0.00% 0.00% 0.00% 0 crypto engine pr
226 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT
227 12000 3 4000 0.00% 0.00% 0.00% 0 Crypto IKE Dispa
228 4000 3 1333 0.00% 0.00% 0.00% 0 Crypto IKMP
229 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
8 4000 2 2000 0.00% 0.00% 0.00% 0 Timers
231 0 1 0 0.00% 0.00% 0.00% 0 CRYPTO QoS proce
232 264000 54 4888 0.00% 0.00% 0.00% 0 Crypto ACL
233 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc
234 12000 4 3000 0.00% 0.00% 0.00% 0 Crypto CA
235 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
236 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
237 434688000 87364 4975 0.00% 0.00% 0.00% 0 crypto sw pk pro
238 0 1 0 0.00% 0.00% 0.00% 0 GDOI GM Process
239 0 1 0 0.00% 0.00% 0.00% 0 UNICAST REKEY
240 0 1 0 0.00% 0.00% 0.00% 0 UNICAST REKEY AC
241 0 1 0 0.00% 0.00% 0.00% 0 MV64 TDR Process
242 0 1 0 0.00% 0.00% 0.00% 0 IMA Traps
243 4000 2 2000 0.00% 0.00% 0.00% 0 Control-plane ho
244 544000 92 5913 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
245 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Track
246 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Resource
247 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Routing
7 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
249 8000 2 4000 0.00% 0.00% 0.00% 0 RMON Deferred Se
250 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
6 8664000 1161 7462 0.00% 0.00% 0.00% 0 Pool Manager
4 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
254 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni
255 3016000 611 4936 0.00% 0.00% 0.00% 0 EEM Server
256 4000 2 2000 0.00% 0.00% 0.00% 0 Call Home proces
257 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
258 0 1 0 0.00% 0.00% 0.00% 0 RMON Packets
259 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
260 0 2 0 0.00% 0.00% 0.00% 0 EEM ED CLI
261 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Counter
262 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Interface
263 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
264 0 3 0 0.00% 0.00% 0.00% 0 EEM ED None
265 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR
266 4000 4 1000 0.00% 0.00% 0.00% 0 EEM ED RF
267 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
268 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
21 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
270 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
271 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje
272 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test
273 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config
274 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env
275 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD
276 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Nf
277 97764000 13645 7164 0.00% 0.00% 0.00% 0 Syslog
278 0 3 0 0.00% 0.00% 0.00% 0 EEM ED RPC
279 4000 2 2000 0.00% 0.00% 0.00% 0 MRIB Process
280 0 1 0 0.00% 0.00% 0.00% 0 Key Proc
281 0 1 0 0.00% 0.00% 0.00% 0 tHUB
283 3540000 579 6113 0.00% 0.00% 0.00% 0 SSH Event handle
284 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
285 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
286 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
287 0 1 0 0.00% 0.00% 0.00% 0 Async write proc
3 4000 1 4000 0.00% 0.00% 0.00% 0 cpf_process_tpQ
172 0 3 0 0.00% 0.00% 0.00% 0 MFIB Master back
145 4000 2 2000 0.00% 0.00% 0.00% 0 RLM groups Proce
146 4000 2 2000 0.00% 0.00% 0.00% 0 L2X Switching Ev
292 612000 128 4781 0.00% 0.00% 0.00% 0 TCP Listener
293 1548000 20 77400 0.00% 0.00% 0.00% 0 BGP Event
997777788888888888888888888888888888877777888888888888888777
117777744444666663333311111444449999933333111115555588888999
100
90 ** ***** ***** **********
80 ************************************* ******************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
999989888988899888898888888889888999888889999888888988888898
213280828135341553131834975772799351946282451776859056542264
100 * * *
90 **##*** ** * **** * * **********#** * *************** **
80 ############################################################
70 ############################################################
60 ############################################################
50 ############################################################
40 ############################################################
30 ############################################################
20 ############################################################
10 ############################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
999999999999999999990999999999999989999999999999998999989999998999999999
672743624443929649690582393231781792253370919873279634797334339917974724
100 ** * * * ** ****** * ** * * * * *** * * * * * *** *
90 ************************************************************************
80 ########################################################################
70 ########################################################################
60 ########################################################################
50 ########################################################################
40 ########################################################################
30 ########################################################################
20 ########################################################################
10 ########################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
05-27-2010 11:30 AM
Hello Darwin,
as we can see BGP is not the main user of resources (not directly at least)
traffic is low as IP input process is not in the first positions
Sorry I didn't ask before, what IOS image is running on the device?
post
sh ver
you may be using an image that is not the best one for this job, or that is affected by a known bug.
post also your BGP config, mask public ip addresses and passwords as this is a public forum
Hope to help
Giuseppe
05-27-2010 11:39 AM
thanks for the reply ... im running the shining IOS
Cisco IOS Software, 7200 Software (C7200P-ADVSECURITYK9-M), Version 15.0(1)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Mar-10 03:32 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
05-27-2010 11:53 AM
Hello Darwin,
I would suggest to try an older image like
12.4(20)T3 or 12.2(33)SRE
IPAM process is not present in 12.4(20)T I've checked on two of my C7200 NPE-G2
Newer is not always better
be also aware that you may be using an IOS image not thought for this use.
Hope to help
Giuseppe
05-27-2010 11:59 AM
thanks for all the help. =)
cheers
