05-27-2010 10:38 AM - edited 03-06-2019 11:18 AM
Currently my router is hooked up to 3 t1s. My connection between the router and main switch is 100 MB. The rest of the LAN is 1 gig. Would there be an advantage to upgrading the router to switch connection to 1 gig ?
Solved! Go to Solution.
05-27-2010 11:36 AM
stephenrm3685 wrote:
Thanks Jon for the info. I can see your point . But what if you had heavy traffic and it bottlenecked ?
Stephen
That is what i meant when i said if the router is purely there to connect LAN to WAN. Because if it is then you are simply moving the bottleneck ie. lets say you have 200Mbps of traffic hitting the router LAN interface. If you set it to 1Gbps there is no bottleneck but the WAN connection with it's T1s is still a bottleneck.
Also i say there is no bottleneck but just because a router has 1Gbps interfaces it doesn't mean it can support anywhere near that throughput.
If your router supported more than 100Mbps throughput and there were other bits of your LAN hanging off other router interfaces that were all 1Gbps capable then yes it would make sense.
Jon
05-27-2010 10:44 AM
Stephen,
It is good idea if you available Gig ports on your router and switch or have the budget to purchase the ports. This way, all your connections are Gig and no bottleneck
Reza
05-27-2010 10:46 AM
Stephen
If the router is there purely to provide connectivty between the LAN and the WAN then no not really as the limiting factor will always be your WAN bandwidth.
Jon
05-27-2010 11:23 AM
05-27-2010 11:36 AM
Stephen
Jon
