ASA/PIX failover trouble with xlate
Answered Question
May 27th, 2010
Hi people,
I configured two ASA 5540 in active/stand by, the trouble is when secundary ASA go to active, the tables xlate are starting  to create and it ,gives me problems, there is some way that both ASA have the same xlate.
thanks
Alex
Correct Answer by JORGE RODRIGUEZ about 6 years 9 months ago
Alex,    look at  couple of links bellow .
you already  have lan failover
failover
failover lan unit primary
failover lan interface failover Ethernet9
failover lan enable
failover key *****
failover interface ip failover 192.168.40.1 255.255.255.192 standby 192.168.40.2
For stateful you will need dedicated interface or share lan failover interface with stateful failover, or you may use a subinterface  for stateful failover implementation.
failover link state
failover interface ip state 10.0.0.1 255.0.0.0 standby 10.0.0.2
See Stateful failover section , as Jon indicated you will need ( failover link )   in order to enable stateful  failover and pass per-connection state to standby unit.
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#statef
Go over some  good guidelines
http://www.cisco.com/en/US/partner/docs/security/asa/asa80/command/reference/ef.html#wp1928149
Overall Rating: 5 (1 ratings)
amartinezr Thu, 05/27/2010 - 14:17
thank you  jon.
the problem is that I have a database server when failover is turned on, connections are rejected by the firewall begins to assemble the xlate table. thank you very much for your help I hope to solve the problem.
the config of failover is this
failover
failover lan enable
failover key *****
and
you recomendation to suggest is
failover replication  http
thanks
m.slotboom Thu, 05/27/2010 - 15:02
Hallo,,
Have you add the virtual mac adresses (active and standby mac address) to the interfaces in the failover config?
Marcel
Correct Answer
JORGE RODRIGUEZ Thu, 05/27/2010 - 15:25
failover
failover lan enable
failover key *****
failover link state
