Is it possible to LWAP config from a WLC
May 27th, 2010
I have a WLC configured with about 40 access  points. Its a WLC-4400 running 6.0. I am trying to create a new WLAN  profile for a couple of Handheld RF scanners. Whatever new WLAN i create  doesnt show up on the available list of the hand helds or a usual  wireless laptop. There are 5 other WLAN profiles which all show up but  the handhelds dont support WPA and hence wont connect. Please help!!!!
Leo Laohoo Thu, 05/27/2010 - 15:50
Are you sure you have enabled the SSID and enable broadcast SSID?
Leo Laohoo Thu, 05/27/2010 - 16:14
Can you ping the management IP address from other wired ethernet clients?
raviprakash_leo Thu, 05/27/2010 - 16:33
yes i can. Its a remote WLC, i login to it from a jump box (a windows terminal server)
Leo Laohoo Thu, 05/27/2010 - 16:41
Have you tried Open (No Authentication)?  What Authentication policies do the handhelds use?
George Stefanick Thu, 05/27/2010 - 18:43
They dont support WPA? What type of handhelds are these?
Also are limiting data rates? Are these 802.11b devices?
raviprakash_leo Sat, 05/29/2010 - 14:09
actually it has very little to do with the handhelds themselves. they are motorolo /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} 9090G-2, but any new networks, even laptops dont detect. All the old ones are showing up in the available networks. I have the WLAN enabled, SSID broadcasted, tried with no security... no luck.
Leo Laohoo Sat, 05/29/2010 - 21:24
How many SSIDs are currently enabled?  The WLC can support up to 1,024 SSID but will support only 16 SSID active at any one time.
weterry Sat, 05/29/2010 - 22:52
Are you dealing with AP-Groups by chance?
The only reason I can think of for a new wlan to not be on an AP is if you are using AP-Groups or if you give that WLAN an ID higher than 16.
raviprakash_leo Mon, 05/31/2010 - 01:09
Yes we are doing AP-groups. There are less than 7 SSIDs. This one has an ID of 7.
What if i am using AP groups, what should i do?
weterry Mon, 05/31/2010 - 06:27
Did you go in to each AP Group and add this newly created SSID?
Any WLAN created (1-16) will be added only to the default-group. You have to go configure each AP Group after a new wlan is created and manually add that new WLAN and the interface mapping to that group.
