Static IPs for VPN Clients?
Hi everyone,
I have what is probably a pretty easy question.
I've got a remote SR 520 router connecting to my ASA via the routers built-in VPN client. The ASA uses my local DC to assign it an IP address via DHCP.
I'd like to know whether it's possible to give the router a static IP address for the VPN session. I suppose I could set up a DHCP reservation on my DC to do this, but there must be a cleaner way.
m.kafka Sat, 05/29/2010 - 02:36
If you use XAUTH (username/password) for your easy-vpn there is an option on the vpn server:
username [name] attributes
allows to set a couple of vpn-attributes per user, e.g.:
lets you specify the IP address and mask assigned to that client.
Use the command-lookup tool for more information on "username attributes"
