SSL VPN feature on G2 ISR 2911
Answered Question
I have an ISR 2911 with a security license.  I am looking to add the feature license for 10 SSL VPN clients.
So far my vendor is not helping at all.  They had me order FL-WEBVPN10-K9.  A package arrived with which had that part number on the outside sticker, but there was no registration info inside, no PAK, nada.
Can anyone help with outlining the procedure for adding this feature to the 2911?
From with in CCP, it looks like I can enter a PAK and then CCP will register and install the feature....?
What is the correct item number for the 10 SSL VPN user feature for the ISR G2?
The documentation I have found so far indicates it would be FL-SSLVPN10-K9
Thank you very much for any info to clear this up.
Correct Answer by Jennifer Halim about 6 years 9 months ago
I've emailed you the PDF.
Overall Rating: 5 (1 ratings)
Jennifer Halim Fri, 05/28/2010 - 04:47
Please try to open with Internet Explorer (works for me just now). I tried with Firefox and it gave me the same File Forbidden error message too.
