All AIP-SSM module logs will be saved in the disk of module itself, not on the ASA.
To check the event logs, log in to the module via https (IDM), then go to: Monitoring --> Events --> default is the last 1 hour, but you can change to what you like --> "View" button.
Learn, share, save
