AIR-ANT2451NV-R
Answered Question
Hi guys,
I have another question about the AIR-ANT2451NV-R antenna: is it compatible with the Aironet 1250?
In the documentation for the antenna it says:
“This antenna is designed for indoor use with any Cisco Aironet 802.11N radio device that uses a RP-TNC connector.”
But the ANT2451NV-R is not listed in the Aironet’s 1250’s supported antenna list :
AIR-ANT5959
AIR-ANT2422DG-R
AIR-ANT4941
AIR-ANT2430V-R
AIR-ANT1728
AIR-ANT2506
AIR-ANT3213
AIR-ANT2460P-R
AIR-ANT2465P-R
AIR-ANT2485P-R
AIR-ANT2410Y-R
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
AIR-ANT5135DG-R
AIR-ANT5135D-R
AIR-ANT5140V-R
AIR-ANT5145V-R
AIR-ANT5160V-R
Thanks in advance!
Correct Answer by Leo Laohoo about 6 years 12 months ago
This document outlines the specifications for the AIR-ANT2451NV-R dual band MIMO low profile ceilng mount antenna and provides instructions for mounting it. The antenna operates in the 2.4- and 5-GHz frequency ranges and is designed for indoor use.
Yes.  That's the reason why this model has six (6) pig-tails.  It's in the release notes of the IOS.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Thu, 05/27/2010 - 22:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Leo Laohoo Fri, 05/28/2010 - 18:08
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings.  I forgot to mention that the AIR-ANT2451NV can also be used on the new 3500e wireless access point (with built-in Spectrum Analyzer).
