Can't Ping Across site to site VPN from ASA to PC
May 27th, 2010
                         I can ping from to PIX to the machine behind the ASA. The VPN is up and everything seems to be working using sh crypto ipsec sa.
hostname SeCuReWaLL
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif outside
security-level 0
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif inside
security-level 100
ip address 192.168.1.6 255.255.255.0
interface Ethernet0/0
shutdown
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
dns server-group DefaultDNS
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 101 extended permit icmp any any echo-reply
access-list 101 extended permit icmp any any source-quench
access-list 101 extended permit icmp any any unreachable
access-list 101 extended permit icmp any any time-exceeded
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list 100
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.2.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set secureset esp-des esp-sha-hmac
crypto map securemap 10 match address 100
crypto map securemap 10 set peer 192.168.2.2
crypto map securemap 10 set transform-set secureset
crypto map securemap interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 28800
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 outside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 28800
dhcpd address 192.168.1.10-192.168.1.40 inside
dhcpd enable inside
username admin password f3UhLvUj1QsXsuK7 encrypted
tunnel-group 192.168.2.2 type ipsec-l2l
tunnel-group 192.168.2.2 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:7e4d8509cd7863b8d2d082195b5521c1
: end
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 2KFQnbNIdI.2KYOU encrypted
hostname lasvegas
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 192.168.2.2 255.255.255.0
ip address inside 192.168.3.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.2.1 255
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
snmp-server community public
no snmp-server enable traps
floodguard enable
crypto map securemap 10 ipsec-isakmp
crypto map securemap 10 set peer 192.168.2.1
isakmp key ******** address 192.168.2.1 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.3.10-192.168.3.40 inside
dhcpd lease 28800
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum:ea418bec1457cebf9284f99a7303fccc
: end
Jennifer Halim Fri, 05/28/2010 - 02:39
  • Cisco Employee,
On the ASA, pls add the following:
     inspect icmp
On the PIX, pls add the following:
fixup protocol icmp error
