LMS 3.2/ Hum 1.2 - Duplicate job views completed
Answered Question
May 28th, 2010
Does anybody has already saw that this default under a bug ?
It concerns Hum 1.2 /LMS 3.2
In the Current Admin/System preferences settings in HUM , the quick report job type "Interface avalaibility" is enable, every hour..
In the Common Services Job , recently completed, 2 jobs have been instancied , at same time, for this quick report.
Richard.
Correct Answer by Joe Clarke about 6 years 7 months ago
From the server's command line, run:
NMSROOT/bin/cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
From the jobcli prompt, type:
delete 4298
Then exit the jobcli interface, and restart Daemon Manager.  The job should be gone.
Overall Rating: 5 (1 ratings)
richard.tetu Tue, 06/01/2010 - 06:12
Hello, Joe,
Please see hereafter an example of  screenshots, taken.
In this example, it's for threshold violations.
I have remarked the same issue for others jobs launched, like in my first remark.
Richard
Correct Answer
Joe Clarke Tue, 06/01/2010 - 10:25
delete 4298
richard.tetu Wed, 06/02/2010 - 04:55
Thanks for this answer.
Question: does it works for LMS 2.6 ?
Richard
richard.tetu Wed, 06/02/2010 - 07:01
Sorry, I did a research on the CISCO support web site , i found that it worked too for LMS 2.6 thanks.
Richard
Joe Clarke Wed, 06/02/2010 - 07:47
Yes it does, but HUM doesn't exist in 2.6.  Deleting jobs using this interface should only be done as a last resort if the jobs cannot be removed from the GUI directly.
