VG30D gateway configuration
May 28th, 2010
Guys,
I have a project that requires VG30D DPNSS converter. I have not worked with these before, hence Ihave been searching through the net to find configuration examples of the vg30d and connecting ISR gateway.
I believe the scenarion should be like this..
ccm>ISR VG>Vg30D>DPNSS Cloud.
Does anyone out there have config examples of both the ISR gateway interface to the VG30D and the config examples for the Vg30D. I need both calling number and name to be passed.
Thank you
