WRV200 = cant hit my DMZ by hitting my WAN Address from LAN
May 28th, 2010
10.10.10.100 - 10.10.10.195 LAN clients
10.10.10.198 (DMZ)
10.10.10.250  (GW)                   <-  WRV200Gateway  ->      98.203.214.60
I can not hit my WAN IP 98.203.214.60 (given to me via DHCP)  while inside from 10.10.10.190
even though my DMZ is 10.10.10.198.
The expected behavour is this
Webserver on 10.10.10.198:80
Windows XP client goes to  98.203.214.60:80
gets the data returned from  10.10.10.198 (but thinks it comes from  98.203.214.60)
Actual results:
Everyone on the outside can access my DMZ
From the inside the Network times out unless I use 10.10.10.198 from the inside.
However DNS all wants to give the inside hosts 98.203.214.60 for an IP!
(dont want to hack intenal DNS for workarround)
I have a Linksys WRV200 Wireless-G VPN Router.. anyone know how to fix this?
(when i replace with DLink with the same config it works)
More info
Routing Table
1 00:1C:F0:13:B8:FF
Destination LAN IPSubnet MaskGatewayInterface
71.231.59.100255.255.255.25510.10.10.198LAN&Wireless
10.10.10.0255.255.255.00.0.0.0LAN&Wireless
98.203.208.0255.255.248.00.0.0.0WAN
239.0.0.0255.0.0.00.0.0.0LAN&Wireless
Default Route (*)0.0.0.098.203.208.1WAN
127.0.0.10.0.0.0127.0.0.1LOOPBACK
Message was edited by: Douglas Miles
douglasrmiles Fri, 05/28/2010 - 04:58
Oh my goodness!
If I shut off DMZ support and i just forward all ports with all protocols to 10.10.10.198 .. the dang thing works!
