CM 4.1.5d with 4.0.19 WAE 7341 , is it supported ?
May 28th, 2010
Hi all,
Is Central Manager with software version 4.1.5d (or 4.1.5e) supported when combined with WAE 7341 with software version 4.0.19 ?
I am specifically using 4.0.19 cause I need to perform a demo showing Replication Mode ?
Thanks in advance.
Zach Seils Tue, 06/01/2010 - 06:53
As long as the Central Manager is running the latest version of WAAS software (relative to all of the devices it is managing), it is fine.  Note that Replication Accelerator mode is supported in all 4.0.x releases from 4.0.19 on, so you should demo with the latest 4.0.27 release.
Zach
