Cisco ACE 4710 Connection Figures skewed
Answered Question
May 28th, 2010
   I am doing some fairly basic loadbalancing with sticky connections based on source IP.  If I do a show Serverfarm XXX command I can see 80 connections going to one server and 890 going to another.
Now if I do a show conn rserver XXX-1 serverfarm XXX | count
show conn rserver XXX-2 serverfarm XXX | count
I can see 165 connections going to the first server and only 9 going to the second.
This sounds about right for the first server considering the in and out connections.  But the second server has me confused with the number showing.  I have tried the clear conn for that rserver but the figure seems to hover around 890 - 900.  Load balancing is Round Robin at the moment.
The second server is functioning ok as I can access it when bypassing the loadbalancer.
We have rebooted the second server and even when the probe-failed status was showing for the server, the current connections from the Show Serverfarm XXX command still showed around the 890 mark.
Has anybody seen this before and know of a way to reset this counter?
Cheers
Brian
Correct Answer by Gilles Dufour about 7 years 1 month ago
we had several issues in the past with the count of active connections in 'show serverfarm'.
Could you test the latest version and if the problem persists open a service request with the TAC to report the problem so we can fix it.
Thanks.
Gilles
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Tue, 06/01/2010 - 00:51
  • Cisco Employee,
Thanks.
Gilles
Brian O'Flynn Tue, 06/01/2010 - 04:03
Thanks Giles, it is good to know I wasn't going crazy looking at those figures.  Will plan the upgrade.
Cheers
Brian
Related Content
