George Stefanick Fri, 05/28/2010 - 09:42
For starts go into the WLC and click on MANGAMENT--> SERIAL PORT
should look like this (default)
Serial Port Configuration
Serial Port Login Timeout (minutes)
Baud Rate (bps) 1200 2400 4800 9600 19200 38400 57600 115200
Character Size (bits)8
Flow ControlDisabled
Stop Bits1
ParityNone
Is your settings correct on your end ?
ALSO you are using a null modem cable, right ?
