ASA, tracking, failover
Answered Question
May 28th, 2010
I'm having a problem when I put in the tracking option on my default route, I lose connection all together.
I have a T1 (outside) used as primary connection, and a DSL line (backup) plugged in for a failover.
This is an ASA with the Security Plus package, so the failover option should be working.
route outside 0.0.0.0 0.0.0.0 1.2.3.1 1
route backup 0.0.0.0 0.0.0.0 7.8.9.1 254
These are my routes.  When I try to put:
route outside 0.0.0.0 0.0.0.0 1.2.3.1 1 track 1
I completely lose connection.  I've even tried "write mem" and "reload" hoping to bring up the connection.
Here is the config that pertains to the routes:
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.253 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 1.2.3.2 255.255.255.248
interface Vlan3
nameif backup
security-level 0
ip address 7.8.9.2 255.255.255.0
sla monitor 666
type echo protocol ipIcmpEcho 1.2.3.4 interface outside
num-packets 3
frequency 10
track 1 rtr 666 reachability
I haven't put in
sla monitor schedule 666 life forever start-time now
Yet because I want to make sure the default route works.  My understanding is that just adding in "track 1" to the end of the route doesn't do anything until I activate the timer with the "sla monitor" line.
Any ideas as to which part of this feature I have wrong?
Correct Answer by Panos Kampanakis about 6 years 7 months ago
I would suggest following http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml#cli
The config will look like
route outside 0.0.0.0 0.0.0.0 1 track 1
route backup 0.0.0.0 0.0.0.0 254
sla monitor 123
type echo protocol ipIcmpEcho interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
I hope it helps.
PK
Overall Rating: 5 (2 ratings)
KWillacey_2 Fri, 05/28/2010 - 10:37
Have you verified if the track statement is up with "sh sla monitor operational-state"? Have you configured the global statement for the backup link?
Becasue if for whatever reason the track fails then the backup should take over as in your case. So verify those two things.
Correct Answer
Panos Kampanakis Fri, 05/28/2010 - 17:42
sla monitor 123
num-packets 3
frequency 10
I hope it helps.
PK
scott.bridges Thu, 06/10/2010 - 22:28
Thanks guys and sorry for the delay.
I didn't know about the show operational state command, which lead me to see that the ICMP was timing out.
I then just started from scratch, changed the instance to the example "123" exactly how it was in the post, and changed the test IP to the T1 lines' DNS server.
All worked after that point.
Thanks again.  I was thinking I could change the "123", which I probably can, but I'll just keep it at default.
