ACE Module not booting up.
alexc2010
Hi All,
My ACE module doesn not boot when i issue the reload command. Also no power enable module 7/power enable module 7 does not work.  The only solution is to physically remove and re-insert the module on the switch.
Please find the output of ACE module booting up below ,it looks like there is a memory error of some sort.  You will also notice that the ACE went into rommon, this was because I was performing a test to get the ACE to boot from an image on the Supervisor.
Unmounting ext3 filesystems...
Unmounting FAT filesystems...
Unmounting done...
INIT: Switching to runlevel: 6
INIT: Sending processes the KILL signal
Rebooting... <1>
sbmac stopped<0>Rest
System Bootstrap, Version 12.2[120],
Copyright (c) 1994-2007 by Cisco Systems, Inc.
Slot 7: Running DEFAULT rommon image ...
ACE platform with 1056876 Kbytes of main memory
Autoboot: failed, boot string  not found
rommon 1 > boot eobc:
boot string configured on SUP is "sup-bootflash:c6ace-t1k9-mz.A2_3_1.bin&qu
ot;
Download Start
Download Completed! Booting the image.
Uncompressing Linux...
Starting the kernel...
INIT: version 2.78 booting
Mounting Second Ramdisk ....
Second Ramdisk successfully mounted
Configuring network interfaces.
CF dump: Register callback functions
dosfsck 2.11, 14 April 2006, FAT32, LFN
/dev/cf: 10 files, 26399/63414 clusters
FAT FS is ok
Compact Flash size 1278624(in 1k blocks) ...
Core file size 208900
Available free size in cf is 796640 (in 1k blocks) ...
set_coredump 2.11, 14 April 2006, FAT32, LFN
first_cluster = 0x608e num_cluster = 0x40 (64)
inserting procfs
inserting isan_kthread
inserting wiremod
inserting klib
inserting resdrv
inserting tlv
inserting sse
inserting kpss
inserting sdwrap
creating sdwrap device
inserting klm_tl
creating tl device
inserting klm_scp
inserting klm_mts
creating mts0 device
creating mtscfg0 device
inserting utaker
creating utaker0 device
creating utaker1 device
inserting sysmgr-hb
creating sysmgr-hb device
inserting modlock
creating modlock device
inserting bufmgr
inserting pkt_fifo
inserting encdec
creating encdec device
inserting pseudo
inserting drammap mod
creating drammap device
inserting ixp_dnld
creating ixp_dnld device
inserting sysdrv
creating sysdrv device
New registry installed.
INIT: Entering runlevel: 3
inserting i2c module
inserting ssa driver
inserting cde driver
inserting bf_dnld driver
inserting pfm_drv driver
inserting regaccess driver
inserting bf_nvram driver
Firmware compiled 19-Sep-07 18:27 by integ Build [26368]
ACE Daughter boards DB1 not present DB2 not present.
downloading fpga to cde 1
Read 2398454 bytes from ./cde1_core.bit
FPGA Date: 2007/12/18 Time: 22:22:1 0
CDE 1 download successful
downloading fpga to cde 2
Read 2377744 bytes from ./cde2_core.bit
FPGA Date: 2007/12/18 Time: 22:22:17
CDE 2 download successful
FPGA Programming Done
CDE 1 revision ID 0403
CDE 2 revision ID 0402
enabling cde 0 interrupts
finished CDE setup
Configuring NP 1 Memory
Configuring NP 2 Memory
Waiting for NP 1 SRAM memory to clear...sData bus error, epc == 00401618, ra ==
004015a8
A_BUS_ERR_DATA_0 0x896c1f00001f6c89
A_BUS_ERR_DATA_1 0x5fdffeff
A_BUS_ERR_DATA_2 0x5fdffeff
A_BUS_ERR_DATA_3 0xffffffff5fdffeff
A_BUS_L2_ERRORS 0x0
A_BUS_MEM_IO_ERRORS 0x10000
uccess
Downloading NP 1 Image
..... 0x4b4b74 (4934516) bytes downloaded
/itasca/etc/rc3.d/S11_setup: line 59:   618 Bus error               ./ixp_prog q
nx.bin 1
Loading Nitrox driver.
Writing register at address 3838 with e00
size = 8108
% IXP 1 XScale Core reset detected !!
Ctx memory range(0x0000000-0x10000000)
Cleared 262144 1024-byte blocks in 5 requests.
Writing register at address 3898 with 1
Writing register at address 38b8 with 1
N2 SPI INIT PROGRAM.
Initializing Nitrox SPI1
configuring using falling clocks
Initializing CDE SPI registers
Nitrox init completed.
inserting IPCP klm
n2_perf_stats loaded
||||$T0a25:c21ecb88;48:801f97f0;1d:8076ff40;#16
Could someone let me know if this is Software issue or the Hardware.
Thanks in advance.Looking forward to hear something on this.
Alex.
Gilles Dufour
Definitely looks like hardware...bad SRAM memory.
004015a8
A_BUS_L2_ERRORS 0x0
uccess
Gilles.
5 Replies 5
Gilles Dufour
004015a8
A_BUS_L2_ERRORS 0x0
uccess
Gilles.
Hi Giles,
Thanks for answering this.
So should I proceed with hardware replacement?
Alex
Alex, yes I would suggest to replace the card.
Gilles.
Hello Guys. Now, I have the same problem with boot ACE.
rommon 8 > boot disk0:c6ace-t1k9-mz.A4_1_0.bin
.Loading disk0:c6ace-t1k9-mz.A4_1_0.bin. Please wait ....
INIT: version 2.85 booting
FAT FS is ok
INIT: Entering runlevel: 3such f
setting /usr/sbin/ipmaddr add 01:00:81:00:00:00 dev eth0
Firmware compiled 22-Jul-10 14:50 by jcbryant Build [25856]
Starting CDE setup
CDE 1 revision ID 050a
CDE 2 revision ID 0501
Finished CDE setup
ACE Daughter boards DB1 present DB2 present.
Powering up DC1 (of DC1/DC2)... Succeeded..
DC1 present, checking if 'DC Rommon' needs upgrade...
DC1 'DC Rommon' is latest, no upgrade needed.
DC1 present, checking if 'DC Controller' needs upgrade...
DC1 'DC Controller' is latest, no upgrade needed.
Powering up DC2 (of DC1/DC2)... Succeeded..
DC2 present, checking if 'DC Rommon' needs upgrade...
DC2 'DC Rommon' is latest, no upgrade needed.
DC2 present, checking if 'DC Controller' needs upgrade...
DC2 'DC Controller' is latest, no upgrade needed.
Waiting for NP's to boot
Data bus error, epc == 00400e2c, ra == 00400dd8
Data bus error, epc == 00400ae8, ra == 00400a98
/itasca/etc/rc3.d/S11_setup: line 310: 750 Bus error ./dc_prog 0 (wd: /itasca/ixp)
/itasca/etc/rc3.d/S11_setup: line 310: 751 Bus error ./dc_prog 1 (wd: /itasca/ixp)
/itasca/etc/rc3.d/S11_setup: line 310: 752 Bus error ./octeon_poll 0x52000000
/itasca/etc/rc3.d/S11_setup: line 310: 754 Bus error ./octeon_poll 0x52000000
What to do with this problem?
Thank you.
Also
/itasca/etc/rc3.d/S11_setup: line 310: 792 Bus error ./octeon_po ll 0x52000000
This service preferaData bus error, epc == 00403ccc, ra == 00403c84
bly be started by the System Manager.
Command line arguments (3):
0: /itasca/bin/sme
1: -c
2: 2
Environment variables:
0: CONSOLE=/dev/console
1: TERM=linux
2: INIT_VERSION=sysvinit-2.85
3: PATH=/sbin:/bin:/usr/sbin:/usr/bin
4: runlevel=3
5: RUNLEVEL=3
6: PWD=/itasca/bin
7: previous=N
8: PREVLEVEL=N
9: HOME=/
10: SHLVL=3
11: _=/itasca/bin/sme
12: OLDPWD=/itasca/ixp
/itasca/etc/rc3.d/S11_setup: line 310: 794 Bus error /itasca/bin /sme -c 2
/itasca/etc/rc3.d/S11_setup: line 310: 795 Bus error ./octeon_po ll 0x52000000
/itasca/etc/rc3.d/S11_setup: line 310: 797 Bus error ./octeon_poll 0x52000000
Please help....
