configure fractional channelized T1
Answered Question
May 28th, 2010
I have a ds3 capable of 28 full channelized T1s.  I need to configure one of them for 768k.  Would I just configure this to say
t1 1 channel-group 1 timeslots 1-12 instead of t1 1 channel-group 1 timeslots 1-24  on the cpe and pe router?  just the pe?
Thank you
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Ikadick,
you need to configure on both ends as both parts need to agree on what DS0 timeslots are usable.
on PE side you need to configure the DS3 and the T1, if the CE has a T1 you will configure only that
Be aware that RED or ADM in the middle may not able to multiplex sub T1 / sub E1 so it may be not possible to use B channels 13-24 for another customer (it depends on RED/ADM capabilities)
see for example:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/10000series/10cfgchspa.html#wp1067532
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 05/28/2010 - 12:02
Hello Ikadick,
see for example:
Hope to help
Giuseppe
