For WCS with location is there a direction to the AP that I need to configure
May 28th, 2010
Some of my mapping shows clients in the parking lot. I know the AP is right and fits with the map. Is the an orientation thing I need to be aware of and how do I know which direction.
thanks
Gary
Leo Laohoo Fri, 05/28/2010 - 18:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Wow.  That means triangulation.
How many APs can see a particular client?  For better-to-best result, I would normally deploy (on purpose to track down a wardriving client) to get a minimum of three (3) APs.  The APs would be deployed not on a straight line but curved or triangle with the middle away from the target.  When your APs have been setup, wait for about 5-10 minutes just to let them sort themselves out and get their "bearings" straight.
Once you've made a good cup of coffee, it's a question of reading RSSI and/or SNR returns.  The higher RSSI signal (syntax "-65 dBm") the closer the target from X AP.
I have a very good experience with triangulation because I've caught a significant number of Australian Federal government staff.  I've been called a number of names but the most "ethical" one is "Wi-Fi Police".
Hope this helps and don't forget to rate useful posts.  Thanks.
Leo Laohoo Fri, 05/28/2010 - 18:56
  • Hall of Fame,
    2017 LAN, Wireless
I hope the 5 APs are not forming a line because the reading can go both ways.  Choose the strongest three signals with the 4th and 5th as a "balancers".  The balancers will help you determine that the target is on THAT side and not this side.  Am I making myself clear or does it seem like the Sauvignon making sense?
william.hostetler Sat, 05/29/2010 - 07:48
They are not in a straight line, however there are all kinds of block walls between most of the detecting APs. I did not designate on my drawings what type of walls they were so for all WCS knows they are just drywall. I may later change that but if I get fairly close I don't mind.
thanks
Gary
sschmidt Wed, 06/02/2010 - 07:07
  • Cisco Employee,
"Some of my mapping shows clients in the parking lot."
That statement worries me.  You should not see a parking lot around your building.  You really need to remove the white space around the building image and make sure that the image with no whitespace matches the building size you defined.  Try this and let us know if it helps.
