Rules,Requirements,Requirements-rules,
Answered Question
May 28th, 2010
Hello friends,
I m very much confuse by reading the Checks,Rules,Requirements,Requirements-rules,Roles-Requirements,
For my corporate i want to do windows update ,antivirus update,USB Pen drive check,
Also i want to know that if any host fails for HSP,for remediation we have to provide a path, Suppose for windows update i want to specify the path for WSUS server what path i can specify ????  It wont work only specifying the IP address of the server.
How i can achieve this????
Correct Answer by Faisal Sehbai about 6 years 7 months ago
Estela,
You can't specify the WSUS server in the requirement. If your clients are managed, they would know where the WSUS server is. If you're pointing to Microsoft servers, they are also known to the WU clients.
HTH,
Faisal
Overall Rating: 5 (2 ratings)
Correct Answer
Faisal Sehbai Tue, 06/01/2010 - 11:53
Estela,
HTH,
Faisal
estelamathew Thu, 07/29/2010 - 15:28
Thanks Faisal,
But in Chalktalk series there is one example where a WSUS requirement has been created for windows Hot_fix.
