PRI rolling to different UCCX Directory Numbers
jyoung
I have a Full PRI installed on location.  The T1 and ISDN circuits are working fine.  If I add a "connection plar opx" to the directory number of the UCCX application, dialing the associated PRI number rings to said application on the UCCX server.  I would like to add a number of UCCX applications that call over the same PRI but to separate called numbers.  I thought if I removed the "connection plar opx" and added a translation-profile which translated the inbound called number to the directory number associated with the UCCX application, it would work, however when I dial the number it rings to a dial tone.  I debugged the translations and it appears that the translation is taking place, however the call is not being routed to the UCCX server after the translation.  Does anyone have any better way to do this or idea how to make this work.
John
You may have an inbound dial peer for all incoming calls such as:
dial-peer voice 1 pots
incoming called-number .
Brandon
Brandon Buffin
John,
     Do you have "direct-inward-dial" on your inbound dial peer?
Brandon
Brandon,
Thanks for the response.  I dont actually have an inbound dial-peer for that directory number, because the UCCX server is directly connected to the CME device.  Should there be a dial-peer for this dn?
Brandon
That was the answer Brandon!!
Thanks Much,
John
