Replace 6724 DFC3b with a DFC3c
May 28th, 2010
Can I replace a WS-X6724-SFP DFC3b with a DFC3c?  If so, what is the part number?  At this time, I will even be willing to change the DFC3b to a CFC.
Tim
Ganesh Hariharan Tue, 06/01/2010 - 04:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Tim
Hi Tim,
the DFC3C will support all the same features as the DFC3B.  The 3C has a faster CPU and twice as much memory then the 3B.  However if you have a Cat6500/Cisco7600 with both types of cards installed in it, the system will operate at the lowest common denominator it will be 3B.
Check out the below link for more information in DFC cards
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_end-of-life_notice0900aecd806d9953.html
Hope to Help !!
Ganesh.H
tim_roper Thu, 06/03/2010 - 11:37
Thanks. Can the DFC3b card be replaced in the field with a CFC?
