Warning message
cannt boot up Cisco VPN 5002
May 28th, 2010
hello
while trying to boot up Cisco VPN 5002, the system comes up to this point -
Initializing free memory...
+ SDRAM mem: base 0x20ae6c78, len 257004424
+   CPU mem: base 0x0000a920, len   1005280
+   Pkt mem: base 0x58000000, len   2097152
Created 128 packet buffers
PCI BIOS: Start initialization
PCI BIOS: Identify devices ...
  Device: bus-00 slot-01 fct-00 : "21143 Ethernet"
  Device: bus-00 slot-02 fct-00 : "21152 PCI-PCI Bridge"
  Device: bus-01 slot-01 fct-00 : "Compress/EnCrypt Device"
  Device: bus-01 slot-02 fct-00 : "Compress/EnCrypt Device"
  Device: bus-01 slot-03 fct-00 : "VPN Key Coprocessor"
PCI BIOS: Map devices ...
PCI BIOS: End initialization
Ethernet 0: 10/100 card in slot 1
Multislot Initialization...
+ Card in slot #1 in 2 slot chassis.  Acting as I/O Processor.
+ Initializing fiber channel
+ Finding Route Processor...
_______________________________________________
attemping to turn the dial to any potsion will not do much,
my goal is to reset the password and bring the system to basic confugraion
Thank you for your help
guy.tetru Fri, 05/28/2010 - 20:17
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello
Thank for your reply,
Here is the message that I get when trying to access the link you have posted..
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
I have the system itself (  pre  - owned ), and I need to do some work on it..
I am aware it's EOL, but I'm positive that there some people out there that knoe a thing or two about it
I have some documentation about the product, but also have a slight suspicion that the product might have a hardware malfunction (or not) .
any advice will be more the appreciated ,
Thank you
Jennifer Halim Sat, 05/29/2010 - 00:12
  • Cisco Employee,
Based on the booting up sequence, if it is stuck at the last sequence that you have posted, it might seem to look like a hardware issue.
I've attached the PDF of the EOL notice for your reference. It's been EOLed since August 27, 2007, so RMA is not even possible.
Maybe someone else has similar issue before.
