Cisco 1131 VLAN Problem
Answered Question
May 28th, 2010
I have configured my Cisco 1131 and it appeared to be working correctly until I ran into my latest issue.  From my PC's I can ping the router, the VLAN interface on the router but I can not ping anything that is connected to the wireless.  My router can ping all of the wireless endpoints, the 1130 can ping all of the wireless clients, but they can not ping each other but can ping anything that is plugged in with a wire.  Vlan 100 is my Data VLAN and I have no idea why the PC's will not talk to each other.  Anybody have any ideas?
Here is my AP config.  If you want to see the router config let me know but I dont think its the router thats causing the issue.
version 12.4
no service pad
service password-encryption
hostname EANET-1131
enable secret 5
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
clock timezone HAWAII -10
ip domain name wrnets.com
dot11 syslog
dot11 vlan-name DATA vlan 100
dot11 ssid EA Net
   vlan 100
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 XXXXXXX
   information-element ssidl
dot11 network-map
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-1204562388
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1204562388
revocation-check none
rsakeypair TP-self-signed-1204562388
crypto pki certificate chain TP-self-signed-1204562388
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323034 35363233 3838301E 170D3032 30333031 30303034
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32303435
  36323338 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C34B 95C450CE 6AD990BC 78FCB1D2 969880A1 23BC2F81 7C7FCF52 CEFF1B90
  86E07928 A2A0AD06 851D9955 EBBD4380 5FC01708 8579A981 BD3625DC 182EAD74
  632DA65C F1AE24B1 E3AB5430 9C872626 FEC0E941 86A7F67F 33D4BB06 BF3F0C88
  EACC1559 AF220A9A 1A96E6BB 5391BBE6 2615B18C 4DCE745E EA9FD4E6 063D8DD1
  78670203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 146F8976 7CE63940 7A4B0E96 E810021F 2BC30515 2A301D06
  03551D0E 04160414 6F89767C E639407A 4B0E96E8 10021F2B C305152A 300D0609
  2A864886 F70D0101 04050003 81810059 518047FF 5CBEE894 AA491041 A5713C07
  EA4550E7 FB0A657B 9AC759C3 DF3B020A 7C602092 6CD92632 12EE62DC 8E61F74D
  454ACB66 D3359BB4 F254940A F7E7AC38 CC5C5A21 2F9D53F0 ECE313F0 2FC5B57D
  415CD5E0 DBD92FD5 43DB0EEB C29DB8A3 3EF24443 664A5D9E 8D3BBA36 AA435FA7
  BE990CEA 08CCEDA3 7F185A64 8825C3
  quit
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 100 mode ciphers aes-ccm tkip
ssid EA Net
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root access-point
interface Dot11Radio0.100
encapsulation dot1Q 100 native
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.100
no ip route-cache
bridge-group 1
interface BVI1
ip address 172.25.1.2 255.255.255.0
no ip route-cache
ip default-gateway 172.25.1.1
no ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
transport output all
line vty 0 4
transport input all
line vty 5 15
transport input all
end
Anthony
Correct Answer by weterry about 7 years 4 weeks ago
Just to clarify, when you say PCs you mean wireless clients? or Wired Clients?
If this problem is only with Wireless Clients talking to other Wireless clients on the same AP, then it sounds like a PSPF issue, but I don't see it enabled.
However, unless you are in Bridge mode, I'm fairly sure this AP should have "bridge-group 1 subscriber-loop-control" under Int do0.100.
As a matter of fact, I don't think you can typically remove this command.
Now, the only symptom I'm aware of when this is missing is that broadcast/multicast won't be seen by the same clients on the same radio, but perhaps that is not the only symptom.
Please confirm if the problem is only Wireless to Wireless on the same AP, or if you have this problem between Wired/Wireless computers.  I'd also be curious how everything behaves with subscriber-loop-control put back on that interface.
Overall Rating: 5 (1 ratings)
Leo Laohoo Fri, 05/28/2010 - 19:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Anthony,
They wouldn't be PC with their firewalls turned on would they?
Anthony Wurtele Fri, 05/28/2010 - 20:23
That was the first thing that I checked.  The funny thing is that I have the wireless and the wired connection on the laptop.  Both in the same subnet and I can ping the wired ip address but not the wireless.  Very frustrating.
George Stefanick Sat, 05/29/2010 - 06:58
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Perhaps span the port on the AP, do a ping both ways and see what is happening ...
Correct Answer
weterry Sat, 05/29/2010 - 22:37
  • Silver, 250 points or more
Anthony Wurtele Sun, 05/30/2010 - 14:48
Thanks for helping me with my issue.   You put it better than I did and you are correct.  Wireless clients (PC's) can not talk to each other wirelessly. If a wireless client wants to connect to a WIRED client, there is no problem.  Its only wireless endpoints that follow this path PC1 (wireless) --> AP --> Router (VLAN interface) --> AP --> PC2(wireless).  That does NOT work.  Now on the other hand PC1 (wireless) --> AP --> Router (VLAN interface) --> AP --> PC3(wired) works just fine.  Very confusing.  The 1131 is in AP mode.
And you are completly correct.  Once I added in:
EANET-1131(config-if)#interface dot11Radio 0.100
EANET-1131(config-subif)#bridge-group 1 subscriber-loop-control
That fixed my issue.
Now I cant even remove it to test it again:
EANET-1131(config-subif)#no bridge-group 1 subscriber-loop-control
no bridge-group 1 subscriber-loop-control not allowed on Dot11Radio0 interface
Do you have any idea why that command was missing?
Thanks for all of your help!
Anthony
weterry Sun, 05/30/2010 - 20:26
Well that is interesting to know that it was preventing peer-to-peer as well, and not just broadcast/multicast.
This is the same problems addressed by "CSCtf36740    Directed Broadcasts do not go out Radio without subscriber-loop-control", however this has not yet been resolved in a release.
The workaround should be valid, as it just involves correcting the configuration that should already be in place. As you saw, you cannot even remove subscriber-loop-control.
As for how the command was missing in the first place: that is what CSCtf36740 is going to resolve. I know it can be triggered by adding/removing/adding bridge-group commands to a sub-interface (like modify what bridge-group that interface is in, after it was already put in a bridge-griup).
Anyhow, I'm glad to hear that everything may be working now.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
