What's differences between bypass traffic and pass-through traffic in WAAS
Answered Question
May 28th, 2010
I'm confuse about it
I know bypass is a function of WCCP that allows a WAE to return redirected traffic that it does not optimized back to the WCCP server.
and pass-through is a method for the TCP proxy in WAAS to forward unoptimized traffic back to the WCCP server
so they both used to return unopimized traffic back to WCCP server
but why cisco said pass-through traffic is not bypass traffic
could anyone help me
thanks
Correct Answer by Sijith Maniyappan about 7 years 12 hours ago
Hi Chia,
Bypass traffic are the traffic which WAAS bypasses and returns back to the Router. The reason for bypassing this traffic could be different - static bypass list configured on WAAS or some overload conditions on WAAS itself. WCCP Return Method is used to return this traffic back to the router.
Pass Through traffic, unlike bypass traffic are accepted by WAAS. WAAS will process the traffic and does Application Traffic Policy Look up  to determine whether it can optimize the traffic. If it cannot be optimized, WAAS will simply pass-through the traffic.This Pass-through traffic make use of the 'Egress Method' configured on WAAS to send it back to the router, similar to any other optimized traffic flow. So depending upon the Egress Method configured, it can be either of IP Forwarding, WCCP GRE Return or Generic GRE Return.
Sijith
Overall Rating: 5 (1 ratings)
Correct Answer
Sijith Maniyappan Fri, 05/28/2010 - 22:53
Hi Chia,
Sijith
