Cisco NIST error
To all Linux gurus,
I installed the NIST but when i typed ./nistnet to start the NIST, i see the following error:
ERROR: Module rtc does not exist in /proc/modules
INFO: etc is not comiled as a module
FATAL: Module /lib/modules/2.6.9_22.EL/extra/nistnet.ko not found.
But then i can see the cnistnet command and it says "DONE"
So is that a critical error or is it just a cosmetic error???
Would appreciated your help.
Cheers,
Hunt
