SPA8800 and PAP2T
May 30th, 2010
I have 6 remote locations that are connected to a main one through VPN over ADSL. I am thinking of using a PAP2T on each location with two analgue phones, and a SPA8800 on the main site with four analogue phones. With this setup I want to be able to communicate from the main site to any  remote site and viceversa. I don't mind if a remote site can call another remote site, although it would be helpfull. In the future I want to add 5 more remote site under the same logic. Are the products I have select cooperate together? Are the best possible solution? Is there any limitation to the number of PAP2T that can be cofigured in the SPA8800? Although there is no PBX to be connected on the SPA8800 still I have choose the SPA8800 with the 4 FXO ports in order to attached GSM gateways. Is this possible?
I know too many questions! Sorry!!!
Thank you in advance
