Specify a WAN for Skype using Linksys RV042
May 30th, 2010
Hello
I need to configure the RV042 in a way that Skype would go to WAN1, while other services to WAN2.
AFAIK Skype uses HTTP, so is there a way to specify that without putting all the HTTP requests on WAN1?
Te-Kai Liu Mon, 05/31/2010 - 11:16
  • Gold, 750 points or more
Protocol Binding allows you to bind http to certain WAN port based on destination IP address. But if the destination IP address is not a static IP, it may not work well if users specify the URL.
zaherzaher Tue, 06/01/2010 - 02:48
Anyone knows to what IP(s) Skype connects?
If I bind VOIP ports (10000-20000) for WAN1, will Skype communications take place through WAN1?
Steven DiStefano Tue, 06/01/2010 - 06:23
  • Blue, 1500 points or more
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I have some info you can find on Skype for SIP, which is a service offered by Skype which allows a SIP trunk (like from from the UC500) into the Skype network which is standards based, not Skype proprietary.
http://www.skype.com/business/products/pbx-systems/sip/
Related Content
