Cisco 3945 Router error while adding in Cisco Works
May 30th, 2010
I have a Cisco 3945 Router and when we try to add the same into the Cisco Works it gives me an error saying " CM0056 Config fetch failed for 192.168.xx.xx Cause: CM0204 Could not create DeviceContext for 1238 Cause: CM0206 Could not get the config transport implementation for 192.168.xx.xx Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
We are using LMS version 2.6. Please let me know the latest router 3945 with support or not.
Thanks in advance.
Thanks & Regds,
