831 Wan Question
May 30th, 2010
Looking to find used Cisco Router for home lab / learning. I have and cable connection that is 30/3. I noticed that the 831 only have wan 10mb. Can this be upgraded? If not what would to recommend for low cost testing. I have several 2600's aswell as 2900xl's that I will be using for coursework.
Thanks for any advise
Leo Laohoo Sun, 05/30/2010 - 23:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
No.
As you mentioned you have some 2600 routers.  That's a good start.  Otherwise you need to fork out some cash for 850/870 routers.
Magician10 Sun, 05/30/2010 - 23:39
The 2600's are 4 x serial units with one 56k card. What would you expect to pay for used 850? Thanks
Leo Laohoo Mon, 05/31/2010 - 15:49
  • Hall of Fame,
    2017 LAN, Wireless
1.  I have no idea what you plan to do but do you know that 850-series do not support multiple VLANs?
2.  This will depend on what WAN port is.  851 is a 10/100 WAN port and the 857 is an ADSL 2+ port.  The latter is very expensive ... above AU$300 .
