Unified Communications Network Management Licensing
May 31st, 2010
i have purchased all 4 VOIP Network Management Software (CUOM, CUSM, ecc...) with their PAK. Now i'm going to register the 4 PAK, but i have a doubt: Cisco requires the MAC address of the server that hosts the Management Software. I have installed the Cisco software on 2 HP dl380 servers with 4 NIC's and, on each server, i configured 2 NIC's in load balance (with embedded HP network software): the other 2 NIC's are disconnected.
Is there someone that can tell me which MAC address i must provide to Cisco PAK registration ?
Thank you,
William Bell Mon, 05/31/2010 - 13:31
Interesting question. When you configured the network team, the MAC address of one of the physical interfaces was grabbed and assigned as the team's primary layer 2 address.  If I recall correctly, this would normally be the first (lowest numbered) ethernet interface.  But it is likely more complicated than that.  But, the point is I would lean to using the mac address reported for the team by the network configuration utility (NCU).
A good doc/pdf on the topic: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01415139%2Fc01415139.pdf
Please remember to rate helpful posts.
