05-31-2010 01:00 AM - edited 03-06-2019 11:20 AM
I need to do a packet capture on Machine A and send the data to Machine B on a Cisco 4506 switch.
I plan to use wireshark as the protocol analyzer to do this.
I would like to confirm that the below way that I intend to do works :-
i) On the 4506, start a monitor session source for machine A and monitor session destination
for Machine B.
ii) On the Wireshark, all I have to do is start the capture right to see all the packets coming to and from machine A.
Would this be correct ? or am I missing anything else here ?
Pls advice,
Cheers,
SN.
Solved! Go to Solution.
05-31-2010 01:18 AM
for Machine B.
Pls advice,
Cheers,
SN.
Hi SN,
Yes this is the method if you want to capture traffic from Host A and to destination Bon the same vlan,Check out the below link for step by step configuration on span configuration on 4500
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Hope to help !!
Ganesh.H
Remember to rate the helpful post
05-31-2010 01:25 AM
before you start capturing, choose the right network adapter from :capture\option
05-31-2010 01:18 AM
for Machine B.
Pls advice,
Cheers,
SN.
Hi SN,
Hope to help !!
Ganesh.H
05-31-2010 01:25 AM
