CCIE VOICE: Globalization and Localization on Voice LAB
May 31st, 2010
Hi folks, I have a stupid question for you guys, should I globalize and localize the calling numbers (according to the calling number type and plan) at CUCM even though they don't ask anything on the lab?
I am really puzzled on this questions as I have seen some of the Cisco documents to follow it, even on SRND they have reccommendation like that, so what we gonna do? Does it have any effect on the points?
Overall Rating: 4 (1 ratings)
Brandon Buffin Tue, 06/01/2010 - 06:58
I'm not sure what you mean by "globalize and localize the calling numbers". Regarding the lab, you will be given explicit instruction about what should be configured. The general rule is, if they don't ask for it, don't spend time configuring it. If they do not ask for this configuration and it is not required to meet another stated task, no points will be deducted. You will also not receive points for including extra configuration not asked for.
Hope this helps.
Brandon
Related Content
