C500 Switch Limitations
May 31st, 2010
Pro's
Request your help in understanding the limitations of C500 Switch. Recently I had  a unsuccessful  support incident in a simple VLAN and TRUNKING environment. I wan unable to get the simple trunk work to carry a access VLAN.
Can any one decipher what do they mean by "
Virtual LANs (VLANs)
Up to 32 VLANs (1000 range) and support for 802.1Q trunking using Cisco Smartports
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6545/product_data_sheet0900aecd80322aeb.html
Thanks in advance,
Overall Rating: 3 (1 ratings)
Ganesh Hariharan Tue, 06/01/2010 - 03:27
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Pro's
Thanks in advance,
Up to 32 vlans can be cofnigured and for trunk configuration you can use cisco smart port to send the vlans to other switches for using 802.1q trunking.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
