Configuration problem with SGE2010-G5
i've recently bought a SGE2010-G5 48 Ports Workgroup switch. The first thing I did was to give the device a static IP Address, 131.237.95.253, with the default gateway 131.237.95.254. Than I used a webbrowser to configure the switch, which included an upgrade to the latest firmware (3.0.0.18). After a reboot (to activate the latest firmware), the IPV4 settings were gone , and also the users that I've created, so I had to start all over again. Also I'm affraid that after a power failure I have to configure all settings again, because it looks like the settings are not stored permanent.
Does anyone recognise this problem?
Michel Oosterom
Related Content
