Federico Coto F... Mon, 05/31/2010 - 06:45
  • Green, 3000 points or more
I'm going to let somebody else confirm this, but I think that MST uses RSTP.
Anything not on the MST itself, will be seeing as another CST, so I assume that PVST will be seen as another CST.
Federico.
Ganesh Hariharan Mon, 05/31/2010 - 23:44
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
I would like to know how MST and PVST can interact with each other ? does mst assume pvst as a CST or not ?
Thanks.
MST is backward compatible with PVST+, Rapid-PVST+, and Prestandard MST (MISTP). MST switch is connected to the other STP (PVST+ and Rapid-PVST+) switches by the Common Spanning Tree (CST). Other STP (PVST+ and Rapid-PVST+) switches see the entire MST region as a single switch. When you connect the prestandard MST switch with the standard MST switch, you need to configure spanning-tree mst pre-standard in the interface of the standard MST switch.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
