CSS 11506 nat to inside
Answered Question
May 31st, 2010
Is it possible that servers behind the CSS to see the source ip address of the request to that of
the CSS in the servers' LAN ?
Example: CSS is connected to the Internet with the ip address 100.100.100.100, has some
servers conencted to it and load balances the connection. The servers' LAN is 192.168.1.0/24 and
the CSS has the 192.168.1.1.
When a connection arrives from 200.200.200.200, from the Internet, I would like the CSS to replace
200.200.200.200 with 192.168.1.1 when it sends the request to a server.
If you need more clarifications, please tell me.
Thank you,
Constantin Blanariu
Correct Answer by UHansen1976 about 6 years 10 months ago
Hi Constantin,
Admitted, I'm not the leading expert on CSS. But I think a source-group configuration would work for you (it did for me).
A source-group is a collection of services, to which incoming traffic will be NAT'ed to a different address. An example could look like the following:
service websrv1
  ip address 192.168.1.10
  keepalive frequency 60
  redundant-index 10
  keepalive type http
  active
service websrv2
  ip address 192.168.1.11
   redundant-index 11
   keepalive type http
   active
And all you need to do is to create a source-group and define the services, to which you want to NAT incoming traffic:
group websrv-clientnat
  add destination websrv1
  add destination websrv2
  vip address 192.168.1.7
  active
This should do the trick. I'm not sure that you can actually define the CSS-address as the VIP in your group-definition, so you might want to select another address.
hth
/Ulrich
Overall Rating: 5 (1 ratings)
Correct Answer
UHansen1976 Mon, 05/31/2010 - 07:31
  • Bronze, 100 points or more
Hi Constantin,
service websrv1
  redundant-index 10
  keepalive type http
  active
service websrv2
   redundant-index 11
   keepalive type http
   active
  active
hth
/Ulrich
Related Content
