05-31-2010 03:54 AM - edited 03-06-2019 11:20 AM
I would like to know what is advantage of SWITCHPORT VOICE VLAN DOT1P , I mean what is diffrence between when I type this and when I do not ?
[I just know it sends voice and data over native vlan (vlan 0 ) ]
Thanks.
05-31-2010 05:35 AM
yes, but the voice traffic should be tagged with 802.1p priority in this case.
for details.
BR,
Milan
05-31-2010 11:02 AM
Thank you so much for your reply , but based on the link again : switchport voice vlan vlan-id based on this command ip phone sends 802.1q priority of 5 .
and with SWITCHPORT VOICE VLAN vlan-id 802.1P ip phone also forwards traffic with an 802.1p pririty of 5.
So what is advantage using second command ?
Thanks.
05-31-2010 11:31 AM
IMHO, there is no advance.
In the first case, the switch will send instructions to the phone (via CDP) to use 802.1q header for voice traffic tagging it to VLAN x.
In the second case, the VLAN tag will be empty (zero), as 802.1p can't be used without the 802.1q header.
In both cases, the phone uses 802.1p priority 5 by default.
See also
and
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094665.shtml#topic2
BR,
Milan
