cucm 7: route incoming fax-calls from pstn to bri interface
May 20th, 2010
hi @ all,
i changed our communication system from ccme to ccm 7.2. now, the ccme is running as mgcp-gateway. there are 4 bri interfaces installed in the ccme. the first 3 bri are connected to the pstn. the fourth bri ist directly connected fo a isdn fax server through a crossover-cable. the fourth bri is configured as network. what setting must i take at the ccm or ccme to route the fax-calls that come in at the 3 pstn-bri´s to route out to the fourth fax-bri? maybe it is possible to route the fax-calls direct in the gateway without sending to ccm.
*** ccme config ***
