Need help on Unity and exchange server integration steps
esa786_2
Hi Friends.
I am looking for the document and steps for full integration of UNITY  with Exchange server ( 2000 or 2005 or 2007). I need the full steps and if you have documents. Pls help me.
Esa
Jaime Valencia
You don't mention the version so refer to the proper guide:
Install and Upgrade Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Hi Jav
Thank you for the reply with the link
Rgds
Esa
