Terminal Server using NM-16A
Ashraf Khan
I was trying to set terminal server using NM-16A module in Cisco 2651XM router but no luck. I did use 2511 in the past without any issue but i don't know if i'm not doing anything wrong with this module as i never set terminal server with this module before. Initially i thought my NM-16A is bad but when i do "sh ver" then router shows 16 Terminal Lines. All i get connection refused by remote host when i try to console other device even after clearing lines. Can anyone please help?
William Bell
You may want to take a look at this doc:
http://www.cisco.com/en/US/docs/ios/interface/configuration/guide/ir_nm16as.html
It has been a while since I have used the async interfaces on a 25xx series device.  I have used the async mod on a 2600 and aside from setting baud rate, parity, etc. I don't recall any special issues.  I have one in my lab now, but apparently I have misplaced my async octopus cables.  Which is a bit disconcerting.
Anyway, hope that helps.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
Bill
Thank you Bill that link was helpful and it is now working.
