Catalyst 3560 Problems
May 31st, 2010
Hi Every body.
I have a Cisco Catalyst 3560 and it has a power suply crash. It was fixed and now it has another problem: When I turn on the switch, it's appear with this message:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
POST: PortASIC CAM Subsystem Tests : Begin
ram_access_test Failed. ASIC: 0, offset: 98809, (wr, rd) = (0x00000000, 0x00020000)
Extended SSRAM Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
After that, it's rebooted itself every time.
Someone can tell me if this problem has solution?
Thanks a lot.
Francisco Velasco.
Reza Sharifi Mon, 05/31/2010 - 07:31
  • Cisco Designated VIP,
    2017 LAN
Hi Francisco,
Seems like hardware issue, possible bad DRAM (memory). If you have a service contract with Cisco open a TAC case to RMA it.
Reza
fvelasco_rojas Mon, 05/31/2010 - 08:14
Ops Mr. Sharifi. t the begining I was thinking in that, but I was waiting for the expert's opinion, in fact, I had a little hope.
I appreciate your help.
Thans a lot.
Francisco Velasco
rahurao Mon, 05/31/2010 - 07:37
Hi Rojas,
I checked the error message and found that it indicates a hardware failure in the POST testing.
Please go ahead and get the switch repalced it may be due to the power supply failure whjich hva caused the failure.
I hope it helps!!
Rahul
fvelasco_rojas Mon, 05/31/2010 - 08:29
Ops Rahul, bad news.
At  the begining I was thinking in that, but I was waiting for the expert's  opinion, in fact, I had a little hope.
Thans a lot.
Francisco  Velasco
