LMS 3.2 License Issue
acharyr123
Level 3
Level 3
I have LMS 3.2 license with me but i don't have the media as it will arrive bit late from Cisco. So i downloaded LMS 3.0 from cisco.
My question is: can i use the same license file for 3.0?
Once i put the license whether LMS will have Version 3.2 instead 3.0?
5 Replies 5
Michel Hegeraat
Level 7
Level 7
Your license is a 3.X license so it will work.
You can also download the installer from cisco
http://www.cisco.com/go/nmsevals
What you get contains the same as the dvd you ordered, it is only packed in a single file
Cheers,
Michel
I am unable to download from the specified url mentioned by you.. I do have privilege of downloading files from Cisco using my cco....
Rgds,
Partha
Interesting, the link seems to be spotty in working. It has been around for a long time and should work consistently.
You can perhaps try going directly to:
https://cisco.mediuscorp.com/market/networkers/productView.se.work?/nxt/rcrs/proieidentity/=17651
The redirect for this url appears to very, very difficult.
I'm not going to the site every other day but I've opened tickets with web-help@cisco at least 3 times.
Unfortunately most of the time it works fine from the "inside", within the cisco private network.
So the guys that should deal with this issue don't take it serious.
podhillo
Please download LMS 3.2 from the following link: www.cisco.com\go\lms and install the license.
go to the featured contents and download the evaluation version.
Featured Content
Download Evaluation Software
Electronically download evaluation versions of the product.
Solaris
Window
Hope this helps!
podhillo.
