ACS 5.1 - auth against different AD groups from one client?
May 31st, 2010
ASA has RA vpn's set up with authentication against TACACS ACS 5.1 based on AD group.
Need to set up access to ASA itself (ssh) based on TACACS as well, to the same ACS box.
Is it possible to have it against another AD group?
Right now, when I create rule, the cryteria to select specific service is based on protocol, client device IP, few other conditions,
and based on that ACS selects rule which in turn may be Network Access or Device Access.
I created two different rules, one is Device Access against Group1 in AD, another is Network Access agains Group2 in AD, and which one is
the first in the list, that is being chosen for VPN access - basing on ASA IP and protocol (TACACS).
Probably workaround would be to enable both RADIUS and TACACS for the ASA and on ACS for this client, and use different protocols for vpn and local device access?
Is this the way?
Thank you
Alexander
