EZ VPN Clients
May 31st, 2010
I have been looking for a command on ASA that shows the number of EZVPN users online at a time. We are running asa803 code on this platform. I was told that 'show crypto ipsec client ezvpn' would do it, but that command is not valid. Thanks in advance for any suggestions.
Federico Coto F... Mon, 05/31/2010 - 09:42
You can try the ''sh cry ips sa summary'' command, it will give you an output similar to the one below:
ASA(config)# sh crypto ipsec sa summary
Current IPSec SA's:            Peak IPSec SA's:
IPSec            :    10         Peak Concurrent SA  :    20
IPSec over UDP   :     0         Peak Concurrent L2L :    20
IPSec over NAT-T :     0         Peak Concurrent RA  :     0
IPSec over TCP   :     0
IPSec VPN LB     :     0
Total            :    10
This shows the amount of connections, you can check the users with the ''sh cry ipse sa user ''
